BurbMan wrote:
gmw photos wrote:
An inward opening door is going to provide you some interesting challenges in making it water tight.
Agreed. When you're going down the road, wind buffeting the trailer is pushing the door closed against the seal on a traditional trailer. There is no pressure coming from the inside. If the door swings in, the only thing holding the door against the seal is the latch.
I would second the idea of looking for a small RV. Yes they are still making cheap TTs but there are also some well-made ones like the Arctic Fox that are insulated and have dual pane windows etc. A steel-sided cargo trailer is not necessarily the best starting point from an insulation standpoint.
I would consider going a little longer, maybe 18'. I know you want to be small and nimble, but if you plan on any winter weather, you will appreciate a place to hang a wet coat or put a pair of snowy/muddy boots that is out of the way. Also a cooktop inside is a must IMO...makes it easy to brew a pot of coffee or make a quick meal without having the start the generator and use the microwave. If you are thinking of "stealth" camping where folks think you're just a cargo trailer, running the generator is not a good option. Overall that extra 3' won't mean anything if you are towing with a 3/4 truck, but will give you the room to add a cooktop and coat closet. Other than that I think your layout is pretty efficient.
Completely different thought....for the type of traveling you are thinking of doing, on the go and not staying in one place, you might be better off with a class B van or a small class C. Easily do-able with your budget, easy to park without attracting attention and has everything already, maybe something like this:
Or possibly a truck camper that fits in the bed of your 3/4 gas tow vehicle. For the monry you are looking to spend, I think you have better options that building your own from a cargo trailer.
:E Thanks for your feedback. I owned an Arctic Fox 31W. Northwood makes a great product, probably one of the best. But, I went through my trailer thoroughly and even Northwood cuts corner on insulation, uses plastic fixtures, the cabinets never stayed closed in transit, they use the same crappy wood toned cabinets that is on my $39 Ikea bookcase and every other RV and quite a few other low quality items. I didn't see that when I bought off the sales lot because at that time like most I'm thinking hey it's got a TV (...dumb) Now, I'm a bit smarter and I'm going to build one the these things the way they should be built and that means there will be costs going into things that don't have retail marketable value to an end consumer. (A dealer can't show or sell a higher value of insulation)
I'm going with a seamless/screwless aluminum exterior. This is the type of material that many over the road trucks use. I might consider going to 16'(only because that's a standard cargo trailer size in the industry) But, I did start out at 13'...and had to creep up slowly to 15'. Coffee pot??? You still have one of those?? I got a Kcup machine and I'd sooner give up a kidney than that :---) I'm not really thinking "stealth", just not looking to draw attention. I want to not look expensive or wind up as the subject of a Dateline episode.
The class C was an option for me, but that would mean when I want to go to the store to say get some milk I'd have to take my purse, my cell phone... oh, and my house!
The wind pressure against the door is something of concern to me and I am going to have to look into that. But I think you are right it's going to have to be secured well. Great comments!
