Bedlam
Aug 06, 2013Moderator
Specularius wrote:
On my 2011 Ford I have to jack the truck up to get the rear stable loads in place. I put a floor jack under the hitch and jack up until the springs are fully extended but the tires are still on the ground. I take them back out when I get home as the ride is very harsh when not loaded.
I use the upper StableLoads on the rear of the overload spring and Energy Suspension stops on the front of spring to give me a better unloaded ride.
If you use the lower StableLoads, they definitely help the loaded ride but make the unloaded suffer. I tested this with pressure treated wood blocks before ordering the lowers which resulted in buying the quick disconnect models instead of the fixed older style.
44,025 PostsLatest Activity: Feb 18, 2025
