- Wo_odyExplorerI love to "fiddle" with gadgets. IMHO, this is way cool.
https://www.youtube.com/watch?v=Yxf7_bRIIWw - dadwolf2ExplorerI measured the distance between the outside of driver side tires and the jack feet and got a measurement. I just put a straightedge, 2x4, rope, anything and make a parallel line going out. Now I just back in with my drivers side mirror looking down at the straight line and back in along that line. Works every time.
- joe_julie81ExplorerHow do you use a magnetic hitch camera?
- 996PilotExplorerI've got just a bit less than 2" between the camper jack and the side of the truck so when backing in I just line up with that gap on both sides then keep it that way. Slow and steady, get out and check at critical points (before the wheel well comes close to the basement of the camper and before the tailgate frame seats at the back of the camper). It takes me about 10-20 minutes from the time I start backing up to when the Fastguns are secure.
- skidsteerpilotExplorerWhat we've discovered is by lowering the driver seatback and watching the process over the driver left shoulder (directly, without mirrors) is much more manageable.
https://thegreygoose.net/wp/2017/11/23/unloading-loading/ - KD4UPLExplorer III always load and unload myself using the mirrors. I don't use anything else to line it up. If you can't tell with the mirrors just get out and look.
- stevenalNomad III put the rear TL tie downs into their receivers, lower the side mirrors, and keep the gap between the front jacks and rear tie downs the same on both sides. From there, just back straight with frequent checking.
- WyoBullExplorerThe key thing, at least in my experience, is to take your time, don't get in a hurry, and get rid of any distractions around you. I also try to use the same process each time I do it so I don't forget to do something. I don't use anything except my side mirrors as well. I get in and out of the truck several times to make sure everything is lined up etc. and that's really all there is to it.
It was definitely a little intimidating the first couple of times loading it but with a little practice it gets easier. - mkirschNomad IIPut the truck in reverse, and back underneath. Like Kohldad I use the side view mirrors. If I'm clear and centered on the outside I'm clear and centered on the inside.
44,056 PostsLatest Activity: Dec 27, 2025
