- Kayteg1Explorer IIWe had long thread about it just few months ago.
In those times everybody wants everything remote-controlled and laser -guided.
But after few pages of debates, turned out it is hard to beat couple of fishing weight hanging under your camper side and lined up with bed rail.
You should find pictures in old topic. - SugarHillCTDExplorerNever had anyone help, I have done it alone for all 5 different TCs.
I built a simple U shaped wooden guide, more like a 3 sided box that is 1/2" wider than the TC footprint.
Having a crewcab truck means that the final 2'-3' of loading is a bit blind since the front of the TC disappears below the rear cab window. - ndrorderExplorerMagnetic hitch camera from amazon. A little pricy. How much are your steps and frustration worth.
https://www.amazon.com/Rear-View-Safety-Magnetic-RVS-83112-WiFi/dp/B01N3UW99I/ref=sr_1_4?ie=UTF8&qid=1520458127&sr=8-4&keywords=battery+backup+camera - dhullExplorer III have a 5 inch piece of bead chain affixed to the front drivers corner on the camper that I line up with the edge of my bed mat. They are both 4 foot wide. Once the mat is centered in the bed you just have to back under squarely and keep dragging the chain up the edge of the mat. Hardest part is keeping it square. A swivel mirror with a suction cup mount is placed on the camper so that I can see where the chain is.
- notevenExplorer IIII load by myself using the tape marker method. I get out and look for squarenesses.
- jimh406Explorer IIII have a stripe in my bed and a stripe on the TC. I've never found having an assistant helped.
- SidecarFlipExplorer IIIAlways load mine alone. Not a big deal. I painted a 1/2" red line vertically on the front centered and I have a pin installed on the front bed rail that I can see looking over my shoulder. I line the pin up with the red line and back under, getting out to check the camper is square to the bed.
Been doing it that way for years. No issue. The trick is making sure your camper is going in square to the bed rails.
I'm sure there are more complex methods but that works for me. - LwiddisExplorer IIAlways took me a while...slow and careful...but I never needed DW’s help.
- fpooleExplorerConstant checking... in and out of truck...
I use the mat, I've centered the mat and then put down Duct/Gorilla tape on the corners so I know where the mat goes.
I then either put on painters tape along the Bed (Flat bed, but the idea is the same - marking) First times it's in/out to verify on the mat.
Then I sit in drivers seat and select a spot that I can relate to on the camper and put tape there to align it up. Trial and Error, but it gives you something to look at for reference.
I'd put something in the center of the camper to use as a reference from the rear view mirror, but it's blocked.
It still takes time and a few times double checking. If you're close to getting it you can 'Walk' the camper over an inch or so...
Just lower the side you want to move out. Raise other side jacks (assuming you have the jacks on the ground). Camper will list a little bit at a time so it's for close adjustments.
I'm sure others have techniques, pick and choose the one that works best in your case.. Some put tape down the middle of bed and camper and able to see it to align it...
Not much help, but some ideas..
Hope that helps.. - BedlamModeratorOn my pickup, I would sight the tailgate gap on my side to load the camper. On my flat deck, I have center stripe taped to my mat and the front of the camper wall which I have to match up.
44,054 PostsLatest Activity: Dec 18, 2025
