Thermoguy
Mar 23, 2023Explorer II
What is your tongue weight? What is the payload available on the truck you are looking at? Is that 7000 lbs loaded or dry weight? My 5th wheel is 8500 lbs on the tires, but almost 11K when you consider pin weight.
It mostly about those 2 numbers, but you also need to consider the stability of the setup with a 1/2 ton truck. Also, is a 1/2 ton truck really smaller than a 3/4 ton as far as the width, length? I don't know if I have ever seen a toyota towing a 5th wheel. Is a Tundra a true 1/2 ton?
44,070 PostsLatest Activity: Aug 05, 2026
