valhalla360
Mar 23, 2023Navigator
Camaurice wrote:
I am thinking of buying a new truck to pull our winnebago micro Minnie 5th wheel. We currently have a 2006 gmc 2500 . I’d like to go with a smaller truck for gas mileage and was thinking of a Toyota Tundra or GMC 1500 4x4. While the trailer is fairly light and we’ve been told a 1500 can pull this trailer, I’d like to hear other opinions. Is there anyone who has any experience towing smaller 5th wheels with these trucks? . Gross Vehicle Weight is 7000 on the trailer.
Go down to your local CAT scale and get two measurements:
- Fully loaded and hooked up as if you are heading out for a trip. (usually about $12-15)
- Park the trailer then weigh the truck (if you do it at the same time, the 2nd weigh is only $2.50-3.00)
Now, you can calculate the total trailer weight and the pin weight with real numbers not guesses.
That said: You are likely around 1400-1800lb for the pin weight (5ers typically have 20-25% pin weight). Pin weight counts against payload and axle ratings on the truck.
1/2ton truck payloads vary greatly. Some are as little at 950lb and others can get up around 2500 (extremely rare to find one of these). Most are around 1500lb payload. You also have to count passengers, gear, hitch and bolt on after market parts when calculating payload you are putting on the truck.
Reality is you will almost certainly be over weight with a 1/2 ton truck even with a realatively small 5er.
3/4 ton truck payloads start around 2200lb and can get up well above 3000lb depending on the configuration. Much better suited to a small 5er. (larger 5ers can quickly exceed 3/4 ton truck ratings).
Will the truck immediately implode if you exceed the ratings...no.
Will it be uncomfortable to drive and potentially dangerous...quite possibly.
