blt2ski
Mar 26, 2023Moderator
the trailers i looked up have what I will call an artificial low gvwr. Yes brochure is 7000 lbs. Empty wt is listed in the 5300-5600 lb on axles, 1100 on hitch. so about 400-500 lbs of payload. They do have two 3700 lb axles.
In my view this trailer can go down the road at 7000 on axles 1400-1600 on the hitch. Which is doable by the heavier setup 15 series trucks. This is granted as large of a 5w I would want to tow. I woukd also assume OP is single or with a soiuse. If OP has 4 adult sized teens as I had, they woukd need a 25 series for oayload purposes
I would also want a 15 with a min 9.5" RA. Toyota jas a 10.5" iirc on some models. At 7' wide, a 5w, aerodynic ussues will be less than a ball mount.
if ordering new, the Ford with the HDPP or GM with its equal would be only choices imho. These two options give those rigs a payload in the 2500-3000 lb relm.
As noted, going from a 4sp auto 25 series, to a newer 15 series with the 8 or 10 spd, even the 6 sp as I have, I went from 10-13 to 17-22 with my GM V6 with equal power to my vortec 350. Better overall performance. I am missing 1500 lbs of door sticker payload. Thats a semi easy fix.
my 02 on this
Marty
my 02 on this
Marty
