Grit_dog
Mar 26, 2023Trailblazer
Marty, the 5300-5600 brochure dry weights are inclusive of whatever the sum of the axle weights AND pin weight is.
Not arguing whether those numbers as published are accurate, but in your post, you tacked on a non existent “additional” 1100lbs pin weight. That should be subtracted from dry weight to get dry axle weights, not added to the overall dry weight.
