blt2ski
Mar 27, 2023Moderator
Jerry,
Looking up the specs, they do say a gvwr of 7000. BUT it has two 3700 lb axles! So the trailer suspension shoukd be able to go higher. The BIG question woukd be frame etc.
When all is said and done, with proper loading etc, the three I saw online at Winnebago are towable by a majority of the 15 series trucks. I can find exceptions, my family of 6 in a crew cab with 1409-1500 lbs of HW, to name one that a 15 woukd not work. Id be pitentially over loading the 9200 gvw 3500's ive had in the past. I woukd pull them as i woukd not be over thee RA by 500-1000 lbs.
IF the OP need a newer truck, a properly setup 15 should be looked at for the reasons they stated. A 15 will not be smaller in size propirtions generally speaking enough to say its smaller.
marty
marty
44,070 PostsLatest Activity: Aug 05, 2026
