mkirsch
Mar 28, 2023Nomad II
Grit dog wrote:
Find a good trans shop now if it just started the shudder. My 2016 (same truck/trans as yours) did that for the first 60k of its life before coming apart.
I took the truck in with a couple thousand miles on it and told the dealer the TQ converter had an issue. Of course “cannot replicate” was the finding. Mine only did it under high load from a stop. Of course you can’t replicate that by driving an empty truck around the block…lol.
I’m all but certain the “shudder “ didn’t do any damage downstream until something finally came apart. Like I said, did it since new, never got appreciably worse, truck was horse whipped pretty hard in that 60k miles. Like bumper pull trailers in the 10-14k range flat peddled up n over the Cascades with 4-5000rpm grade braking comin down the other side.
Then one day it started acting up.
I never read about the issue much (company truck, didn’t care) but from a practical standpoint I’m 90% sure a new tq converter before it self destructed would have saved the trans without propagating more issues.
Hope this helps.
And the 4wd issue is likely unrelated (fortunately or unfortunately depending how you look at it).
Is your 02 an Alli or a 4L80? 100k miles maybe a bit more is a good/average lifespan for a 4L60/4L80.
The 1500 has a shudder/shake to it sitting at a light, but only sometimes. Shifting to neutral causes it to stop.
Transmission temperatures are pushing 190 just driving around, which is what's really bothering me. I never really paid attention before, but I can't remember it getting that hot, even towing.
The 02 is the Allison. 52,000 miles on it. Throwing P0700, P0843 and P0875 codes... All just say something amorphous about "low pressure" which is a "WELL DUH!" from me... It won't move!
Sorry to the OP for hijacking. I won't discuss further.
