Dirtpig
Dec 28, 2012Explorer
Help me buy a solar panel
I need advice on what solar panel to purchase. I have 2 group 31 batteries holding i think 220AH. All we do is dry-camp, only plugged into electricity a couple times. Electrical needs are very minimal, we do not run any electronic gadgets other then the radio/cdplayer. Even lights are not used all that much as we spend 90% of our time outside. In the winter this changes to more lights and more electicity used because of the furnace but i figure solar is going to do very little for me in the winter time if anything. Right now (in summer) we are able to camp for about 5-6 days with the batteries going down to about 12.1-12.2V and then i will run the generator. I am hoping to get away from this generator use all together.
We live/camp in mountainous terrain so i would say 6hrs of good sunlight at best, probably fair amount of shadows during the day cast onto the panels from trees as well.
I already have a solar panel controller (Specialty Concepts Mark15, 15amp) I was thinking a 100watt solar panel would maybe be OK, should I go bigger? Should I add more then just 1 panel? Tons of room on the overhead cab part of the camper but its slightly angled downward.
What do you think?
Good brandname? specs to look out for?
Probably purchasing in quartzsite AZ unless you know of a good place to buy.
What do you think?
