drsteve wrote:
gmckenzie wrote:
I have an equalizer. Only downside to it is you can't play with it if you load differently. Once set up you can't just drop an extra chain link if you are towing with or without water. So is I tow with a full load of water, the truck squats a bit more than I like. I think the Blue Ox is better for this.
But this doesn't happen often for me so it isn't a big deal.
Sure you can. Just move the bar saddle on the trailer frame up or down. Each bolt hole gives you about a chain link worth of difference.
Isn't what I consider "playing" with it if I have to break out the wrench and breaker bar. It's nowhere near as simple as dropping a chain link.
