wizwor wrote:
In this thread, I would like to stick to the premise I put fourth -- an all season slide in that can be carried in an F150 which will sleep four in a pinch. If this ends up being unfeasible, I will start a new thread where we can discuss the merits of various tow vehicle options. Truck Camper Warehouse is on my list of camper dealers.
I started with Lance because their site has an F150 filter which identifies the 650, 825, 865 as appropriate. The 650 sleeps 3, the 825 sleeps, the 825 sleeps 4/5, and the 865 sleeps 5. I have been in the 865 and it seems like a suitable camper to me. Wet weight is 2011 Lbs. Add 600 Lbs. for people, and you still are a couple hundred pounds under the payload for any of the 2017 long beds per http://www.fleet.ford.com/resources/ford/general/pdf/brochures/2017/2017%20F-150.pdf. The 825 is 1837 Lbs. dry.
This is my starting point -- a slide in that can be carried on an f150 which will sleep 4 adults.
I have not been in a Palomino backpack, but, on paper, an HS6601 @ 2051 Lbs. seems like a nice camper. Ditto for the Real-Lite HS1804 at the same weight.
As far as timing goes, I will not be buying a camper in 2017 unless an unbelievable deal falls in my lap. I may even push the truck into late 2017/2018 if my focus passes inspection again .
The point of this investigation is to determine if an f150 is suitable for a suitable truck camper and, if so, what configuration (engine, bed, cab, accessories) should be purchased with the truck.
thanks...len!
Please read the red type. The poster has not challenged any posts. There is no reason to Flame or Troll for any subject, no matter how many times it has been discussed. Things are forever changing, including trucks and campers. If you are aware of previous threads on the subject, post them. If you have additional info, experience, resources or simply want to be involved in the discussion please post. If you simply want to argue, do it somewhere else.
Wayne
Moderator
