westend
May 20, 2018Explorer
Your Liberty is going to struggle, at times, pulling a hard sided trailer. Check your frontal area towing restrictions and keep the weight as low as possible. I'd assume that you have an adequate transmission cooler. If not, install one before towing.
The added drag of a hard side trailer is something you may be not prepared for. I'd suggest to rent a trailer similar to the size you anticipate buying (can even be an enclosed cargo trailer) and experiment with a short trip.
