busterbrown73
May 21, 2018Explorer
westend wrote:
Your Liberty is going to struggle, at times, pulling a hard sided trailer. Check your frontal area towing restrictions and keep the weight as low as possible. I'd assume that you have an adequate transmission cooler. If not, install one before towing.
The added drag of a hard side trailer is something you may be not prepared for. I'd suggest to rent a trailer similar to the size you anticipate buying (can even be an enclosed cargo trailer) and experiment with a short trip.
What ^^^^^^^ they said. A Jeep Liberty is no match for most hard sided trailers. Maybe a Scamp or such, but you'll be in a very small confined space. If you're able to upgrade to a larger tow vehicle (ie Durango, Yukon), your options would open up tremendously. Even something like a Chevy Traverse would be more substantial than a compact SUV Liberty.
