jimh406
Apr 12, 2017Explorer III
Welcome!
Going 150 lbs over GVWR is probably not a great deal if that is all it is.
Their website implies those are starting base weights which means anything they consider an option will add to the weight. Batteries, propane, and water may be above that weight as well as tie downs etc.
You should think about how you will camp. If there are shower and bathroom facilities nearby, then a shower is obviously less important.
