Ranger_Tim
Apr 12, 2017Explorer
Don't trust what anyone says. Take the truck to a truck stop and weigh it without the tailgate and a full tank of fuel. You will then have numbers to use for calculating your payload. Figure out the wet weight of the camper using Travel-lite's dry weight plus the water, propane, batteries and gear that you will include. Figure on a weight of gear in the truck too. Then compare with the actual truck payload, wheel and axle ratings for your model/year.
You will then have data upon which to base your decision. Guessing is a gamble that may result in happiness or heartache. Be armed with facts and you will probably be happy! Surprises are not welcome when it comes to spending thousands.
