westend
Jun 29, 2018Explorer
Your converter produces 12V power when 120V is fed to it. If your lights are bright, the converter is probably OK. You should have a 120V breaker panel. Turn off all circuit breakers and flip back on. Make sure your water heater is not being powered by 120V. Turn it off if it is an electric water heater.
Good luck, more members can help if you list the make and year of your TT.
