93Cobra2771
Aug 15, 2016Explorer
FYI - hitch height is the last thing you adjust. You adjust hitch angle and such until you have the correct amount of weight distribution. Then you adjust the hitch height.
It would be helpful for you to post a pic of your setup. Those bottom mount couplers can be a bit of a bear to get set correctly due to being so unique.
Also, check your hitch and make sure it can't be flipped to add more drop. Some can, which helps fix the problem.
The dual cam setups actually work very well with the bottom mount couplers due to the extra clearance they provide.
The links listed earlier in this thread are excellent sources.
44,071 PostsLatest Activity: Aug 30, 2026
