HaulinBass02
Aug 15, 2016Explorer
Sorry if I said round trunnion bar! I know the difference I just typed incorrectly! I have round bars.
As far as the shank and head are concerned, I've already flipped it from where it was and dropped the head as low as it will go. I have a new longer drop shank on the way.
I'll spend next weekend and get the hitch setup better. Probably won't get a dual can anytime soon but at least the WD will be setup right and be a little more stable back there.
On a side note, have any of you ever had a friction sway control "stick" and cause the trailer to track funny? It seemed that after a hard turn one way or the other, the trailer would tend to "push" the suburban the direction of the last turn! I could correct it by doing a small "s" turn but I don't ever remember that happening with our first trailer with a frictions type sway control. I tightened it per instructions on the control but I wonder if it was TOO tight?
44,071 PostsLatest Activity: Aug 30, 2026
