jmtandem
Aug 17, 2016Explorer II
The longer shank will make no difference in chain length. My advice: get the dual cam installed and start loving it. It is a great system.
Times Two!!!
I went to the Cequent (Reese) Dual Cam set up instruction and they recommend a rear hitch head tilt as well. They recommend about five links and as straight as possible (vertical) chains. (The exception to tilt is if you have a bottom ball coupler.) There are also several good You Tube videos on how to set up the dual cam. Good luck.
44,070 PostsLatest Activity: Sep 18, 2026
