Davisfamily8182's avatar
Jun 06, 2015
Help setting up wd
I need some help, more like reassurance that im setting this up. I have read alot on this and am looking at the set up directions just wanting convermation that i am doing the right steps.
Specs
1997 foord f250 hd
2005 trail light 30 ft 8304-s
wd resse duel cam anti sway.
Hooked it up for first time, for me anyway, 5 links on chain and very little tension on bars. Do i need to rotate head so bars point down more before adding tension so that there is more tension when pulled up?
Thanks for the help before hand.
  • It has the teeth on the side i guess you call them if they point down when full weight is on the set up do i rotate ball towards truck or trailer
  • At 5 links are your bars parallel to the trailer frame? It sounds like you do need too rotate the head and if you have the type of hitch I think you do you'll need to ad a couple of washers. I have too jack my Expedition up until the rear wheels are almost off the ground before I can connect the bars without the pipe. Oh, and welcome to the forum I hope we can do you some good.
  • Let me correct that after double checking i had miss counded links. Still jacked up and 5 links it takes no effort to pull up and put in safty pin
  • Are you jacking the tongue jack up before connecting the chains?
    You should jack it up till you're about a half inch or more above level, then connect the chains, and lower the jack. This will give you the tension you need...
