mtnman1989's avatar
mtnman1989
Help! shopping for a TC
We are thinking about getting our first used TC.
We do a lot of winter forest camping and think the TC is right for us.
I own a full size 1/2 ton 4X4 truck with a 6.5 foot bed.
What size TC can I put in this truck?
I want to stay lite weight as possible.
I found a Shadow Cruiser popup that weighs 980 pounds but I think it is too long for my truck bed?
Is there a rule about how much hangs over the bed or tailgate?
Any comments?
mtnman
  • mtnman, same here... F-150 4x4 6 1/2 foot bed... I run an 8' Pastime camper that weighs 1400lbs dry as I recall. I'm definitely over GVW, but within Axle ratings, and GCVW when I tow.
    Do you know it weighs that 9xx lbs? or is that what the sticker says? If sticker, it's likely to be heavier than that.
    You'll have to pack sparely, which I do to keep things light. But putting a TC on a 1/2 ton isn't even remotely as impossible as some guys on these forums think it is.
    Later
    C
  • Weigh your truck and subtract that weight from the trucks payload.
    Your rear tires and wheels will be the limiting factor because you will carrying most of the weight on the rear.
    If the camper hangs over the rear you can damage the bottom of the camper if the tailgate is in place, just be careful if you do that. Damage to tailgate from stones kicking up as well .
    tailgate info
  • I think a pop up would be perfect for your truck. I always had the tail gate down with my TC and never had any problems.
    Good Luck!
    Josh
