Rbertalotto wrote:
Follow all this and you will find your problem. If it were me, I'd start with the last item first - the tire wearing only in certain spots, plus that tire running hotter, to me says the you have a tread separation happening. Often, just jacking up that one tire and spinning it, while looking at the tread surface, will show "wobbles" or "humps" in the tread and/or sidewall. This needs immediate attention
Thanks....turned out to be a bent wheel. Which happened last February when I lost a wheel bearing.
Pretty easy fix...thanks for reporting back and letting us know.
Thanks!
Jeremiah
