Hi,
I will try and help. This pic of yours
![](https://images15.fotki.com/v1669/photos/2/36012/14619112/P1010399-vi.jpg)
That wear pattern points to an excessive toe out condition. There may be a small amount of negative camber mixed in too. But I would suspect excessive toe out to the main issue. Basically, the wheel is at a toe'ed out (pointing outward) angle to the direction of camper travel. This condition creates a high scrub angle to the road and is burning/wearing up rubber just going forward.
You mentioned you used a level on the wheel, that is a good quick check "but" in order for it to be accurate, the camper "must" be parked on a true level spot were both the left and right tires are on the same level spot. Once the pavement under the tires is dead level, then you can put a level on the rim and see what you have. A wheel that is exactly level means it has close to 0 degree camber. Which points towards the axle tube being at total capacity. Under less than total axle capacity, the top center of the wheel should be pointing outward from the camper indicting positive camber. When the top of the wheel points inward towards the camper that is negative camber and comes from axle overload or bent axle spindle/tube.
Your level check may not be accurate.
If you want to drill down into sorting this out yourself and you have access to some basic tools and some advanced the further you want to check it, see this post.
TT axle alignment & install - Detailed (long lot's of pics)In the second paragraph is a link to my prior tire wear investigation. Between the 2 posts, a level, some spacers, a tape measure and an amount of knowing what to look for you can see big picture what may be going on.
Your camper does not look new by the cracking paint/rust on the frame and do not know how many years you owned it or if you bought it used. You may have inherited a manufacturing issue from the factory with hanger locations being off. Or the axle tube became bent along the way. And that combined with excessive spring bushing wear and or axle weights.
Have you ever weighed the camper axle by axle? And ideally by each wheel location. All 4 tires are not normally loaded equal. Many times 1 or 2 tires are loaded more than the rest. Camper floor plan and how much cargo is stored on which side can create a heavy wheel. On the heavy wheel the spring will flatten more and will change the location of the axle. This is normal but when the weights or spring gets very flattened, then it can be part of a tire wear issue along with other factors. Meaning this may be a combo problem, not one smoking gun.
Since it "looks" like your truck mirrors are in the pic, this heavy wear tire is the left rear tire. Yes/no? That means the rear spring hanger and bushing set on that rear leaf spring is creating the location setting of the axle. If the hanger is out of location, the wheel will be out of location too and out of location in relation to the front axle assuming the front axle is even in the right location. And or the you have an axle spindle that is bent outward.
Did this just happen, like in the last 4 months or you never towed that long and hard with it before to notice? Is this the 1st or 3rd set of tires on the camper you put on? If you measure tread depth across the face of all 4 tires you can see if all 4 wheels are rolling in alignment.
The tire you have now, you said it is not wearing the same all the way around. HEADS UP, the tire may be coming apart inside. A spin test can help tell that. Jack up the camper and spin that rear tire. Place a board as a feeler across the OD tire face. Spin the tire slowly and mark where you started. The OD should run true round. If it has a section with a hump, the tire can be starting to come apart inside.
See this video of me doing a spin test this spring when my BFG LT tires had tread separation. This was the 3rd one I caught before it let go. This link will take you to my Flick'er site with the short video
https://flic.kr/p/HxGnZpThis location was the out of round area
![](https://c1.staticflickr.com/1/912/40312358730_7756d9870c_o.jpg)
The wood tire feeler touching the high spot
![](https://c1.staticflickr.com/1/825/27248791457_02e0a4f603_o.jpg)
The clearance off the high spot
![](https://c1.staticflickr.com/1/832/27248792087_d6c83dd80b_o.jpg)
Inside the tire coming apart
![](https://c1.staticflickr.com/1/912/41399154374_bd5bde2286_o.jpg)
If you have an out of round bump condition like that, change that tire ASAP. It is on borrowed time. Put the spare on and be looking for a new tire to get back a working sound spare. In your situation you really do not want to be without a good working spare. You will be wearing the spare when you put it on in that location.
Hope this helps
Let us know what you find.
John
