Executive45
Jun 30, 2015Explorer III
Further investigation appears you have a Thetford Aqua-Magic IV model toilet with the hand flush. If this is so, you pull the handle half way forward to add water and all the way forward to flush. Apparently this isn't happening. So I've revised my trouble shooting for you.
1. Turn water OFF.
2. Remove water line from toilet.
3. Have someone briefly turn water ON and then OFF. See if you get water out of the line. An easy way to do this, if you don't have a helper is disconnect the water line from the toilet and turn on the water pump. Switch should be in the bathroom with you. See if water comes out of the supply line. If it does then your water valve inside the toilet needs to be replaced.
I have included the owner's manual in the click link below. There's an 800 number for questions....Dennis
Owner's manual
1. Turn water OFF.
Owner's manual
