Jeepers92
Nov 21, 2013Explorer
Make sure your cables and cable ends are large enough to handle the winch. It pulls a lot of current when operating, which dissipates a lot of heat, which causes more gassing. Make sure there is no grease between the battery post and the battery clamp unless it is conductive grease, even then it can cause the connection to be loose. Grease is ok used on the outside of the connection.
44,056 PostsLatest Activity: Dec 10, 2013
