Tom_Barb
Feb 18, 2023Explorer II
rv...ru? wrote:
I'm trying to figure how what kind of truck I need for a camper, and after doing some research I'm still a bit confused.
The lightest campers I've found in my general area/budget are in the range of 1,700 - 1,900 lb. From my understanding, this would be too heavy for a half-ton truck in most cases (in addition to the dry weight of the camper, I've estimated that I'll need another 800 lb for passengers, max fresh/grey/black water, and misc. items, plus I added a 10% buffer... this comes out to a total payload of about 2,900 lb).
So it looks like this might work for some three-quarter ton trucks, but more likely I'll need a full-ton truck? I know it will depend on the particular year/make/model/trim, but I was hoping to avoid full-ton trucks due to the cost. Am I making any mistakes in my approach here? And are most trucks fine for campers as-is as long as the payload capacity fits, or is it also recommended to upgrade stuff like the suspension/tires/etc. regardless?
Any help would be much appreciated.
we used a 1 ton dually, for 4 years, get the biggest truck you can a 450 dually preferable. these bigger campers sway a lot.
We see a few frame mounted campers that an idea too.
