bob213 wrote:
Look for one with Azdel walls. Newest material, less chance of delamination since it contains no wood or luan.
Might look at Forest River Surveyor
Surveyor with Azdel
OP, only if you buy into the RV manufacturer Azdel marketing BS, because most only use it for one layer somewhere in the construction so they can put the word Azdel on brochures and other advertising. Surveyor is no different than Coachmen and many others,the only place Azdel is used is the sidewall outer layer directly behind the Filon skin, everything else is wood. The floor has wood, the roof has wood, the front and rear walls have wood.
I love the other claims also, higher R value and less weight with Azdel. I do not know how you get any R value of 1/8" of anything. Since a typical 30' trailer would use about 15 sheets of Azdel in the sidewall, and they claim it weighs 50% less than wood, you just saved 82-1/2 lbs because a 1/8" thick sheet of luan plywood weighs 11 lbs.
Marketing crapola which people buy into.
