KimandChris's avatar
KimandChris
Help with tire wear
I have an AF 1140 with a 48 inch Torklift Superhitch/truss system to pull a 7x12 tandem axle cargo trailer. Also use a wd hitch. The trailer sits just slightly nose high when parked on a level surface. Here is the best pic I could find:
I am getting wear on the outside of the tires on the front axle. Passenger side is worse but also happening on driver side. My thought is a bent axle. With the odd(for everybody but people in this forum) setup I am wondering if maybe it is a combination of the heavy TC/long extension/wd hitch. I know I use much of my suspension travel going over bumps on the highway. No bottoming but my guess is the deeper into the suspension the truck goes the more the WD hitch is removing weight from rear axle of truck and front axle of trailer.
Any thoughts on what to do?
