hohenwald48
Apr 30, 2016Explorer
lukenick wrote:
I did all the measuring of the wheel wells and am definitely distributing enough weight to the front axles.
It's impossible to know this without "hitched with bars tensioned" and "unhitched" weights of the tow vehicle. Measuring fenders is just an approximation. Many on here and other boards have suggested that you get some real scale weights.
Until you have that information folks can only guess as to what your problem might be. After you get it weighed folks can give educated suggestion for a resolution.
Look forward to hearing what your actual weights turn out to be. Remember to get TV front axle weight, TV rear axle weight and TT axle weights when you go to the scale. Not sure if a "salt truck" scale will give the needed info. It may only be a 1 or 2 platform scale and not a 3 platform scale.
