Grit dog wrote:
Do you guys ever get tired of the same old stories?
Of course it’s better to hand pack the bearings, but it’s also worse to not have enough grease in there and that can be cured quickly and easily with a few shots from a grease gun through the EZ lube.
But you’re right, you don’t even want the cavity that full. More like half full of grease in between the bearings, tops is what I shoot for.
I do get tired of wrong answers and try to add some common sense, only to be ridiculed by the usual suspects. This subject is about a useless "feature" pushed by the RV industry as a selling point to those that don't understand.
A few shots of grease will do nothing for the outer bearing. Half full again will do nothing.
