Congrats on the new rig!!!
If not the HA or PP, I would suggest the Reese Dual Cam or Reese SC as mentioned. 1500lb or 1700 bars available. The 1700lb bars may be for the DC only, can't recall for sure.
The biggest obstacle with the HA or PP is the max 1400lb tw. So depending on your new trailers dry tw, the floor plan, and how you load, you may be fine, or may be limited by the max tw rating of the hitches. The Equal-I-Zer is also limited to 1400lbs tw. Also a good choice pending the tw if the HA or PP are eliminated.
Good luck deciding!!!
