eipo
Mar 02, 2016Explorer
Hensley or....
With the purchase of our 35' (OAL) trailer, I am curious if a non top of the line hitch will prove satisfactory? It isn't abnormally tongue heavy for the truck, but will certainly benefit from sway el...
BarneyS wrote:
Someone several pages back said that your picture showed the hitch head to be centered on the trailer. I disagree! Your picture shows the hitch head turned to the right (bottom in the picture). This means that the right hand strut bar is too short and the left one is too long. You need to adjust them very accurately so the distance from the edge of the orange hitch head to an identical point on the frame on each side is the same. Then you tighten the adjustment nut and lower the adjustment arm over the top of the strut. This will lock everything in place and the hitch head cannot move left or right.
The symptoms you described are consistent with the struts being either not adjusted correctly and/or loose and your picture confirms this. It has nothing to do with the spring bar adjustment whether by jacks or chains.
You MUST get the hitch head centered on the A-frame via those struts or the hitch will not operate the way it should.
Hope this helps. :)
Barney
