hawkeye-08
Jan 05, 2015Nomad
CampingN.C. wrote:TURK2500 wrote:BurbMan wrote:
snip.....it sounds like you really need 1400 lb bars to send more weight forward......snip
BurbMan,
I agree on the higher rated spring bars, but the OP stated his TV front axle weight "unhitched" (truck alone) was 3,180lbs, and "hitched" was 3,580lbs......., I would be inclined to reduce the weight transferred to the front axle (unless I'm misinterpreting OP's CAT data). I would tend to use the CAT data over fender heights.
Bob
No, you're reading it right.
3180 without bars
3380 6 links
3580 5 links
So I'm transferring 400# of 1400# tongue weight to the front axle.
3180 without bars (is this with NO trailer hooked up?)
3380 6 links
3580 5 links
