BurbMan wrote:
JBarca wrote:
This points to the camper maybe not balanced just right yet, truck tires being an issue and WD not set correct followed by possibly a nose high camper.
While we haven't talked specifically about levelness of the rig, I don't think nose-high is the problem. Reason I say that is because the TT tows better when the OP tightens the DC. At 6 links it tows terrible but tows better at 5 links...taking that extra link raises the nose of the TT which in turn improves towing characteristics, so therefore nose-high shouldn't be what's causing the sway.
I agree that the camper is not balanced just right, but the question is whether it's even possible to get this particular unit balanced so that it tows right. What's amazing to me is how heavy the tongue is even with all that weight of the double slide and outside kitchen behind the axles. How did Joe manage his tongue weight to keep it under 1250?
Hi Don,
I agree right now, nose high is not a major piece of this but when running the DC trying to control a camper 35.5 ft long, heavy TW everything has to be optimized.
1. Camper has to be balanced right. He has 15% TW, now the truck has to handle it.
2. Tire pressures and side wall stiffness have to be right. Front tire Pressure helped him but he has a rim width issue. It is hard to pin point this as the brand/type of tire plays in this too.
3. WD settings and WB bars loading the truck suspension have to be optimized. This is still on going.
4. The truck also has to be up to the task. His 2500HD while close on pulling capacity has a lot of load capacity left so he is not fighting suspension capacity.
5. DC has to be setup correct. This can help the sway but should not be part of the bucking.
6. Trailer stance needs to be in line. Level is best, next best slight nose down. High nose up can in some cases aggravate sway.
All 6 have to be dialed in so no interactions are created from them. When your on a witch hunt, don't rule any piece out. It was like when I had the Michelin LTX tire issue on my 2500 Burb.... Everything was right and then I changed tires...
Joe and his Ex on his older 32BHDS, his did not have the rear outside kitchen and it was about 1.5 feet shorter. I remember he had to shift things inside to help lighting up the tongue to keep it at 1,250. And he did not have a 86 gallon fresh tank. He put a lot of stuff in the back of the EX. He had to add the Helwig sway bar and the RAS rear suspension to the EX to deal with the EX soft springs. He almost had the DC setup solved but gave up as he felt to close to the edge. Then later he learned about his rear tires even with the Hensley that they may have made a difference when he was on the DC.
I sent Bob an email to see if he can chime in. His rig and NC's are really close.
John
