Reisender's avatar
Oct 02, 2021
High profile tires on off road packages on trailers. hmmm
Hello all. We are closing in on ordering our little 18 foot teardrop trailer. We chose to not get the high profile larger rim size tires as we want to keep a low profile and the tires add a couple inches, not to mention the chihuahua will have a hard time with the higher step. :) We are also pulling with an SUV so lower is better.
But for conversation sakes, it seems really common nowadays to see little trailers with big storky tires on them. I can't help but think there would be significant mileage hits because
a. the trailer is higher and bigger going thru the air
b. it seems those kinds of tires would be less efficient being dragged down the road.
c. Finally, are they easy to find if one has a bad string of blowouts?
Cheers all.
  • Skibane wrote:
    True, true, and maybe - depends on which particular tire size they are.
    One advantage of them is higher ground clearance, which reduces the chances of rocks and other objects snagging something on the underside of the trailer.
    In some cases, they're sold with a "high-lift" axle option that also increases ground clearance a bit.
    Some trailers have low-hanging dump valves which are prone to road damage, so a couple extra inches of height can be worthwhile - particularly if you like to take the trailer off paved roads.
    Yah I suppose clearance can be good for some more extreme type towing. I think we’ll be fine without the extra 2 inches of clearance. We’ll be dragging it on and off ferries quite a bit though. Hmmmm.
    Thanks for the input.
  • True, true, and maybe - depends on which particular tire size they are.
