HadEnough's avatar
HadEnough
Hit a newly installed speed bump. Water tank replacement??
I have a Dodge Cummins turbo diesel and Arctic fox truck camper. It has the true tie downs.
I hit a speed bump that was newly installed in an area that I normally drive in.
This sheared a couple of the bolts on the tie down system at the frame. It also broke my water tank.
I'm limping my way about 4 hours away today to get a campground. Normally I don't use campgrounds. I'm going to decouple the truck and truck camper and get some welding done on the tie-downs. As well as the sheared bolts replaced.
The big question is the water tank. How do I best access this? Do I have to go in from the bottom of the truck camper? Through the flimsy material they use to seal it off? What is the best way to reattach that material later? It's like cardboard or something. In fact, it's all falling off at the rear of the truck camper where it hangs off the back of the truck anyway. I've had to use some wooden slats to try to hold the material in place. I would love to pull this tank from inside the truck camper so that I don't make much of a scene at the campground. But I'm afraid I have to go in from the bottom of the truck camper. Any advice on this water tank replacement project? Has anyone done it before?
This is going to be a speedy water tank replacement. I'm going to work on it full-time at the campground. 8 hours a day until it is finished.
Additional damage includes a slightly crushed wheel well. Just in case anyone is curious what can happen when you get airborne with a truck camper. LOL
  • You have to remove the bottom of your camper to access the fresh water tank as it's suspended by nylon webbing to the frame. You can't replace it from the inside of the camper. Was the tank full when your incident happened?
  • Something isn't adding up. Speed bumps aren't placed in locations where vehicles travel at speeds that would allow them to become airborne and break a torqlift tie down.
    Anyway, I don't know where your water tank is, so I can't say how to remove it. All the ones I've seen can be accessed from inside and would be easy to replace and service.
    As for the tie downs, if they are torqlift, they will most likely send you a new set to install...I would go that route since you paid so much for them.
    I'd recommend speaking with the campground owner about your repair; you will probably have better luck communication with him first so that he doesn't freak out when he sees you rebuilding a camper.
  • True tie-downs is the brand name. They seem pretty awesome. Extremely rugged. Definitely not the problem. The speed bump was the problem.
    Here they are.
    http://www.torklift.com/index.php/products/tiedowns/tie-downs?w_page=tie_downs
  • Sorry to hear this. I have been airborne with mine but was lucky. I dented the bed and front rail of the truck. Lots of stuff came loose inside. The spring loaded fast guns only help so much.
    I am not sure what you mean by "true tie downs". Maybe that was part of the problem.
