Artie32249's avatar
Artie32249
Hitch Height
I have a brand new 2015 ALiner and my TV is a 2015 Ford Flex with towing package. Using the straight hitch that I had the rear of the camper is slightly higher than the front and I've read that it should be towed (and stored when closed) with the back slightly down. If I get a 2" drop that will only give 3/4" rise when flipped over and I don't think that would be enough to get it level, let alone the front higher than the back. The next drop is 4" which gives a 2 3/4" rise when flipped. This seems like it would be too severe. Are there any hitch drops between 2" and 4" because those are the only ones I can seem to find.
  • I have found it is easier to tow and less sway if level with the tow vehicle.
