Grit_dog
Jun 21, 2021Trailblazer
Mickeyfan0805 wrote:Baja Man wrote:
Based on one of the responses...
Does weight in truck bed need to be considered when selecting a WDH?
Ex. TW is 900# and truck bed has 500#....hitch and bars need a 1400# rating?
Can't speak for all hitches, but Equal-i-zer specifically includes any cargo behind the rear axle in the calculations for hitch size.
Not that I doubted what you said, but read it for myself and I can’t figure out how or why Equalizer would say to use cargo load to calculate hitch load. It literally doesn’t make sense unless someone has a clearer explanation.
What it sounds to me is Eq is attempting to prep folks to buy hitches that also assist in lifting part of the cargo load. I mean, I suppose so, but only applicable if your vehicle is having difficulty with the cargo and tongue weight.
This phenomenon that virtually “any” weight off the front axle is bad, is mind blowing in most any typical situation with a full size truck or suv or larger (hd, diesel).
Think about it. Base model single cab V6 2wd pickup. Lightest front axle curb weight, right? Is it unsafe? Nope.
Add V8 and 4wd. What’s that a few hundred lbs more on the front? What if it handled like the base V6? Oops that’s the same with a little tongue weight off the front.
Just go up from there. Bigger engine, heavier tires and wheels,crew cab, overweight driver and passenger, solid 4wd hd axle and the big one, a diesel.
So what if 1000lb tongue weight takes 250 lbs off the front axle of a V10 4wd F350?
What happens? Not a **** thing other than slightly better front tire wear…
Little common sense and experience goes a lot farther than a $500 steel bandaid between your truck and trailer.
I won’t even get into “sway”. Just like tongue weight, too heavy for truck = needs wdh. Too light of tongue or axles too forward or a lot of weight far aft in the trailer = need for sway control if you can’t change those inherent “conditions.”
So the need for a wdh is somewhat cancelled by the need for sway control. :h
If you don’t believe me, you guys are observant, right. Start watching how many cargo trailers or TT delivery drivers use a wdh compared to weekend warrior TT owners. The difference is staggering. Heck ask a TT hauler if you don’t believe the guy who’s an engineer, mechanic, construction guy and all season trailer tow-er for 30+ years.
There is a time and place for wdhs but ALOT of weekend warriors just drink the koolaid proliferated by RV dealers and websites like this, rather than understanding the basic weights and mechanics of their setups and forcing themselves to be skilled drivers.
