Tequila
Jun 29, 2014Explorer
You also have to check what the hitch itself is rated for. Many trailers have forward storages and of course there are the batteries all of which increase hitch weight. Mine in fact has nearly all its storage ahead of the axles. You can always add something like a torklift superhitch and not have to worry about it. The equalizer bars will transfer some weight forward & back.
You can also consider adding supersprings or airbags if you feel your tongue weight is too high. Too low a tongue weight induce sway.It is easy to find that you shoudl have at least 10%, but finding out if there is an upper limit, assuming the rear end of the truck can handle it) is more difficult
