bgum
Jun 29, 2014Explorer
TW will be about 450-550lbs.
WD not necessary but Sway contol is. You may get some squat from the weight.
You do not need a WD hitch for sway control. Online you can buy a stinger (look up sway control adapter) that has the little tab off to the side for the small ball. That way you save on hitch weight at the very rear of your truck.
