Hi all. When I read TT spec listings some will give the hitch/tongue weight along with the dry weight and GVWR. Can anyone specify if the hitch weight listing would include the weight of LP?
No....your dry weight does not include propane. Then again it would depend on the mfg if they include it or not.
Either way...the weight of the LP tanks should not be a concern, that small amount of weight is not a huge difference. If it is, you are likely way too heavy.
