"Bigbird65 wrote:
I have a Husky Friction sway control (P/N 34715/37498)which seems to work well when adjusted properly but does pop and groan when turning at slow speed. I would like to be able to get rid of this noise by lubricating and still get the anti sway action. However, the instructions say: Important: Do not lubricate. Comments?"
Bigbird. pull the bar out of the unit and clean up the slide with a wire brush. You do need to lube the two ball connections. Doing both of these suggestions will help quiet a friction sway control like yours.
