Grit_dog
Jul 20, 2015Trailblazer
So the frame is 49" wide? Basically the same width as the camper.
2x4 frame will be fine. You're transferring most of the load through direct compression on the outside edges. Use 2x6 band boards held flush on the bottom if you want a lip on the sides.
If the band board sits outside the frame you can always block between the joists right over the trailer frame if you're worried about compression on the joists.
Save the $ for joist hangers. Not needed.
Assume you're going to sheet the top of the deck?
44,066 PostsLatest Activity: May 13, 2026
