This is the front panel of the EU2000i 2KW Honda Generator
This is the front panel of the Companion 2KW Honda Generator
Having the companion model allows you to slave the two 2KW Generator together and not have to provide the additional 30A connection panel as shown here.
Being included with Companion Model all you need to do to slave the two units to use the 26.6 AC AMPS total output is connect the sync cable like shown here
Without syncing the two units together you only get 13.3 AC AMPS output from each generator unit.
Roy Ken
