97Bigfoot
Feb 23, 2014Explorer
Honda 2000 generator
Anyone out there running a honda 2000 genny on propane? If so what are your likes and dislikes and how does it compare db wise to gas? Input greatly appreciated
Bumpyroad wrote:jauguston wrote:
Bedlam,
If you do a little research you will find the generator watt maximum output is reduced by about 20% when using propane fuel due to its lower energy content. This is the same for any gas engine converted to propane fuel.
which is another reason that I would get the 2400 for a few hundred more. and since you aren't going to take it on a hike, the extra pounds would not be a show stopper, IMHO.
bumpy
jauguston wrote:
Bedlam,
abslayer wrote:kerry4951 wrote:
If I spend the money I want one that I know will run my 11,000 BTU AC unit. I feel that the Yamaha 2400 Hybrid is up for that task, so I guess I would have to put up with the larger physical size and weight.
My Honda EU2000i runs my 11,000 BTU AC unit just fine.
In fact with a test run it ran my 11,000 BTU AC unit for 6.5 hours on one small tank of gas in Honda before stopping , got to like that:)
Ramp Digger wrote:
When purchasing my new Honda 2000,I ask the sales person about a propane conversion for it.His reply was that honda does not offer them and does not suggest using them.Also doing so would void the warranty. Just saying.
Ramp
jauguston wrote:
The propane conversions for generators require high pressure propane.
Flyfisherman128 wrote:
Tapping the high pressure line is the only way to go. Everything has a regulator.
