afraid_of_bears's avatar
Aug 19, 2013
Honda eu1000i voltage question
I just noticed that my Honda generator is putting out 124-125 volts. Is this normal?
  • According to the spec sheet for this unit, the output voltage is 120V, 1000 Watts Max. It does not list any tolerance for this voltage. So, if you're seeing 125 Volts, you are running about about 4% over the rated voltage which is probably okay.
  • Sounds a bit high. Just to be sure, what are you measuring the voltage with?
  • This would be when running just the converter to charge the batteries. Fridge is on propane.
