Turtle_n_Peeps
May 31, 2014Explorer
dieselenthusiast wrote:bfast54 wrote:dieselenthusiast wrote:
The Yamaha is starting to look appealing because I can get a propane kit for it!
http://www.yamaha-propane-natural-gas-generators.com/
You can get a propane kit ,for Honda also......WORD OF WARNING..... right from Tri-Gas propane......THE PROPANE GENERATOR IS VERY THIRSTY.....
Try,,100 lb cylinders......you know the Tall ones,outside Food Trailers,food trucks...
Take his advice.....and HE SELLS PROPANE....
The kit that I'm looking at does not consume a lot of propane. "For instance, a portable 20# grill type propane cylinder is equivalent to 5 gallons of gasoline." Plus, the kit also allows you to run gasoline and natural gas. You can read more about it here:
That would be impossible. Propane only has 73% of the energy of gasoline. That means you will use about 25% more propane than gasoline. Link
44,071 PostsLatest Activity: Aug 30, 2026
