Huntindog
May 31, 2014Explorer
dieselenthusiast wrote:Turtle n Peeps wrote:
That would be impossible. Propane only has 73% of the energy of gasoline. That means you will use about 25% more propane than gasoline.
"Is there any power loss when operating on alternative fuels?
No, we have never had a single unit show a loss of power on alternate fuel. Though lower gallon-to-gallon in BTU content, sometimes they perform even better than running on gasoline (see also fuel consumption). The engine regulator we install has an external fuel mixture adjuster that can be turned with your fingers and can be fine-tuned to your elevation and to the fuel supply connected. That's why we include the Engine Hour/Tachometer Meter with every generator. You can watch the engine rpm output while turning the mixture adjuster for peak performance and high efficiency. This allows full control over the fuel mixture no matter what elevation. Unlike operating on gasoline where the carburetor is a fixed jet and it can not be adjusted only replaced. This is a big advantage that allows the engine to be reset at anytime. Engines would not use the same fuel mixture in different areas especially as diverse as say Florida would be to Colorado. Unlike gasoline, setting the mixture lean on alternative fuel is cool running, clean burning and efficient."
http://www.yamaha-propane-natural-gas-generators.com/faq's.htm
They are blowing smoke up your.....
Go to the Onan webite. They have been making RV generators forever. Most all of their units can be equipped from the factory to run on propane. ALL of them are rated for less power, and high propane consumption vs. their gasoline twins.
44,071 PostsLatest Activity: Aug 30, 2026
